New system. Need help (1 Viewer)
Austin Pectol
Austin Pectol
New House has a pre installed system. I have speakers and a surround sound system as well, but my speakers just have speaker wire and the wall port looks like this.. .. Need help on what to use to get everything set up and working?
xx Brian xx
Brian
Those take speaker wire. You can either loosen the outer shell and insert the speaker wire from the side through the exposed hole, use a banana clip and push it straight in from the front or use a spade connector. You may have to pull the wall plates off to see which side is positive and which one is negative.
Brian
zoobird
