new Subwoofer < $400
Discussion in 'Archived Threads 2001-2004' started by Steve & Karen, Aug 4, 2002.
  1. Steve & Karen
    Steve & Karen Stunt Coordinator
    Mar 10, 2002
    78
    What would folks reccomend in the way of a Subwoofer list price new of under $400...?
    Steve
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
  3. Max Malloy
    Max Malloy Stunt Coordinator
    Oct 1, 2001
    71
    SVS for sure! Grab this one for $329 and then an amp for $150 or so. That's a bit over your budget, but the quality is well worth it. And if you can afford to spend a little more, consider going up to the 29-39CS... or the PCi.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    For SVS, if you're going to spend $480, you might as well just get the 25-31 PCi for $499 complete. I can definitely recommend SVS also, but we are talking about room vibrating, heavy duty sub and that may not be what you are looking for. The 25-31PCi is simply shocking [​IMG] (that's a good thing [​IMG] ) What is the application? Movies/music %, serious rumbling or just to fill out the bottom octave? Size of room?
  5. Max Malloy
    Oct 1, 2001
    71
    Yeah that's the way it is with HT. the 39 is just 50 bucks more than the 31, so why not go with that? And since you've already spent that much, might as well add another 50 and go for the best PCi. And then before you know it, you're spending $700 instead of $400. Plus taxes, and you just doubled your budget. That easy! [​IMG] That's what happened to me when i was shopping for a receiver. First it was Denon 1802, then 2802, then i said f*** it and bought the 3802, which costs as much as two 1802's. [​IMG]
