new sub help
Discussion in 'Home Theater Projects' started by jeff hedderson, Feb 1, 2005.
  1. jeff hedderson
    jeff hedderson Auditioning
    Jan 14, 2005
    11
    Could some one send me in the right direction to find drawings on subwoofer design.Some different designs other than the basic ported enclosure.Also needing some ideas on some crossover and filter designs.Thank you much.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Probably want to ask in the DIY section...
    Cylinder would be my next choice if you don't want to go with a box. If you don't want a ported box, go with a SEALED one [​IMG] X-over design is no simple task. If you haven't done one before, you may simply want to consider an amp that has the x-over built in.
    There are also plenty of DIY kits out there too.
    www.partsexpress.com and www.madisound.com have plenty of DIY stuff.
