Firat Cingi
- Nov 9, 2005
Hi all,
I have Teac PLS 85D home theater system. It's one of the lowest-end option available (unlike most of you guys' systems ) I mostly use it for dvd, and audio cds.
Although it satisfies ny needs I wanted to upgrade my speakers and these are the two options available. Another option is keeping mine. They are Teac speakers (30W*5 + 50W subwoofer):
--> Jamo E 350 PPL
92 dB Sensitivity
2 channel speaker system
2*140W+3*100W + 70W Subwoofer (6 inch)
8 ohm impedance
Frequency range 55-20000 hz
--> Sony SA-VE356
5*120W + 120 W active subwoofer (~4 inch)
Frequency range 28-50.000Hz
6.1 channel
Would you please help me choosing one. My A/V receiver is an 5.1 channel one. And I assume I can use Sony on it. I don't have funds to upgrade A/V receiver so if both speakers systems with an output power of approximately 500W will be useless on this receiver please tell me so.
--> Jamo E 350 PPL
92 dB Sensitivity
8 ohm impedance
--> Sony SA-VE356
6.1 channel
