New speakers $500-700 or so....
Discussion in 'Archived Threads 2001-2004' started by Chris Trot, Nov 27, 2002.
  1. Chris Trot
    Chris Trot Stunt Coordinator
    Jan 4, 2002
    81
    Happy Thanksgiving...
    Hello,
    I'm looking to purchase some new speakers, I currently have:
    JBL S-center
    Klipsch Quintet rears
    Sony SM-40 sub
    and no fronts so to speak
    My question is, if I get other speakers other than say some JBL S-38 is the matching going to bother me
    Any suggestions for this price range ($500-$700)
    Any help would be greatly appreciated!
  2. Brian Burgoyne
    Brian Burgoyne Second Unit
    Jan 9, 2001
    325
    I would just stick to JBL if I were you. If you wanted to switch brands and get something in comparable quality to the S series JBL you would have to spend more money. You want the front 3 speakers to be timbre matched at the least. There is no rush to switch out the rears, but you could do it eventually with some JBL S 26s. I would do the fronts first and then get a new sub myself. For $399 + shipping you could get a Adire Rava sub that would be a great and very noticeable improvement.
  3. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    Chris,
  4. Frank Carter
    Frank Carter Screenwriter
    Mar 12, 2002
    1,187
    If you do like the JBL's, you could get the S36 and S26 from etronics.com for $400 plus shipping. With the rest of the money, I would invest the rest in a quality sub. If you sell you're Sony and Quintet's and use some left over money you could get the Adire Audio Rava($399), find a used Hsu VTF-2($around $350 used), or put a few more dollars in and get a SVS 25-31Pci($550).
  5. RussKon
    RussKon Stunt Coordinator
    Oct 31, 2002
    184
    Chris,
    The consumer JBL speakers are ok. but before you spend the money on the JBL, I would recommend listening to the RF-3 by Klipsch. Much more detailed sound and actually closer to the JBL Professional line that is out there.
    The RF-3's are about $600 to $700 for the pair.
    Go to audioreview.com to check out the reviews by current owners of the RF-3's.
    Russ
  6. Chris Trot
    Jan 4, 2002
    81
    Thanks for the help!
  7. Robert_Gaither
    Robert_Gaither Screenwriter
    Mar 12, 2002
    1,370
    I'd advise that the front 3 should match irregardless if possible (you could always buy another JBL center and use both for rears). I'd advise set up your front 3, sub, and then the rear pair (since you already have the Klips, it should do for the moment).
