John Leppert
- Jun 7, 2003
Selling my new Sony 34" Hi-Scan® FD Trinitron® WEGA® TV
model #KV-34HS510
This is Sony's newest model. Paid $2000, will sell for $1500. Pick up only in Peoria, IL.
Excellent picture and plenty of connections for everything.
• 16:9 FD Trinitron® Picture Tube
• Hi-Scan 1080i™ Display
• Memory Stick® Media Playback (JPEG)*
• HD Detailer™ Wideband Video Amplifier
• DRC™ Digital Reality Creation™ MultiFunction Circuitry
• CineMotion™ Reverse 3-2 Pulldown
• Two Tone Cosmetic Design
• ClearEdge VM™ (Wideband Velocity Modulation Scanning)
• Wide Modes
• DVI-HDTV Interface
• MID™-X (Multi Image Driver-X)
• Twin-View™ Two Tuner Picture and Picture
• Scrolling Channel Index™ System
• Multi Image Driver (MID™ X) Circuitry - With Sony's Twin View™ 2 Tuner Picture and Picture you can watch 2 full motion pictures side by side. Together, Twin View, and Sony's proprietary Multi Image Driver X Circuitry allows you to view analog along side of HDTV at the same time on the same screen. Also, with MID™ X both picture images are improved to 480 progressive image quality.
• Wide Modes
• Video Features
• Dynamic Focus™ Circuitry
• Dynamic Picture™ Circuitry
• Trinitone® Color Temperature
• Vertical Aperture Compensation
• Vertical Center Adjustment
• 3 D Digital Comb Filter
• Auto Program
• Caption Vision (CC)
• Channel Fix
• Channel Label
• Channel Skip/Add
• Clock/Timer Two Event
• Energy Star® Compliant
• Favorite Channel With Preview
• Front Button Menu Control
• Picture Freeze
• Channel Jump
• On Screen Display (English/Spanish/French)
• Program Palette™ (Vivid/Movie/Standard/Sports)
• Tilt Correction
• Sleep Timer Function
• Speed Surf™ Channel Selection
• V Chip Parental Control
• Video Label
• Auto Pedestal Clamp
• Auto White Balance
• High Voltage Regulator
• Audio Features
• TruSurround® SRS® Audio (15W x 2)
• Steady Sound™ Automatic Volume Control With BBE® Audio Effect
• Auto Mute Tuner
• Auto SAP
• Audio Output (Fixed/Variable)
• DVI-HDTV Interface (Digital Visual Interface) - has been added for the latest generation in high definition television connectivity. A single wire delivers a full digital uncompressed HD signal that can be received from any DVI set top box.
• Hi-Scan 1080i™ Display - Sony's Hi-Scan1080i™ TV's accept the full 1080 interlaced scanning lines (1080i) or 720 progressive scan (720p) from an external HDTV receiver or a compatible high definition digital satellite receiver. It also accepts 480 progressive (480p) scanning lines from compatible DVD video sources.
• HD MicroFocus(tm) CRT's - By using an impregnated cathode and a denser phosphor layer, this CRT produces a 30% tighter beam spot compared to previous models.
• Digital Reality Creation™ (DRC™)-Multifunction Circuitry - This Sony proprietary technology displays four times the picture resolution compared to conventional models for excellent picture quality.
• CineMotion™ Reverse 3-2 Pulldown Technology - is a fixed algorithm irrespective of source which preserves the integrity of movie film frames to create the best possible image
model #KV-34HS510
• Wide Modes
• Wide Modes
• Video Features
• Auto Program
• Channel Fix
• Channel Label
• Channel Skip/Add
• Picture Freeze
• Channel Jump
• Tilt Correction
• Video Label
• Audio Features
• Auto Mute Tuner
• Auto SAP
