RussellTodd
- May 17, 2004
I recently just received my KV-36HS420 it Sony's latest 36" HD tube tv. However, I have a question about one of the features Clear Edge VM™ Wideband Velocity Modulation it supposedly lets user select levels to create better separation between object and its background for clearer edges, greater picture depth and improved overall picture quality. I comes from the factory with setting on High which seems ok for TV watching especially on high def channel the images look extremely sharp. But when I play video games the lines look to harsh. Bear in mind I am using componet cabels for TV and S-video for gaming. Does anyone have experinece with "Clear Edge VM" and found a good setting that will do both well. You can chose between high,med,low,off. What is recommeded?
Also, I have read in this forum that you must change the factory settings off of "torch mode". There are 4 choices of settings "Vivid", "Standard", "Movie", "Pro". I assume if I switch from "Vivid" to "Standard" I should be fine. However, I have to put it back into "Vivid" in order to see my video games. Will the hurt the TV if use "Vivid" for gaming only so long as only play for about an hour at a time then put it back into standard for regular TV viewing?
Sorry to be long winded but I'm just ointerested how other Sony owners have thier TV setup and what works best.
