New Sony ES receivers... crappy digital sound?? (1 Viewer)
Sebastien David
Hey guys, haven't posted in a long time, but I was getting all excited about the new Sony ES line of receivers, with their digital amp technology, it seemed to be the advent of a new era... then I saw the THD numbers, which were HIGHER on the higher-end models than on the non-digital-amplified base STR-DA1000ES. Weird, but I decided to wait and see (or hear) before judging.
They look great, and as can be expected from Sony, offer a very complete range of setup options and features. One day I show up for work at the store, and lo and behold, there was a brand-new STR-DA2000ES installed in the sound room!
Now I had heard a lot of raving comments from people here on the Sony S-Master digital amps, so I was expecting something good. But my coworkers, who took a listen before me, told me the unit sounded like crap!
So I went and made sure the settings were the same, matched the volume, put both units in stereo mode with sub on, and proceeded to do an A-B comparison using CD music.
Well gosh darnit, the Sony did sound like crap compared to the Denon AVR-2803 I used as comparison! It sounded ok on its own, I guess, but when we switched to the Denon unit, BAM!, there was the real sound we should have been hearing...
So I guess that's a disappointment, except if I got a faulty unit, which is doubtful because everything worked properly, or if the Sony digital amps need a lot of break-in time. I thought the contrary, because of the digital amps and all, but hey, I can be wrong...
So anyone else take a listen to those units? Is the STR-DA2000ES an exception, or is it representative of the rest of the Direct Drive Digital amplifiers in the new Sony ES receivers?
Lee Scoggins
Atlanta, Georgia
Lee
Specs can be very misleading when it comes to sound quality.
I just listened to the new Sony ES line and I was very impressed and I'm not someone who normally dips into the receivers-I'm a separates guy.
I have not heard the 2000 but maybe it is not their best.
Sebastien David
Interesting Lee... maybe they cheaped out on the 2000 and this compromised the sound quality by a wide margin... I'm really looking forward to comments and reviews of the higher-end models before I finalize my opinion on the subject.
ChrisWiggles
I was not impressed with the sony digital amps at all. There were some threads about this i believe, but maybe im confusing the forums. Regardless, IMO the digital amps in those just don't cut it. I am sure somewhere there is some good digital amps, but this doesn't seem like it :-/.
And yes, specs can be very misleading.
Phil A
Central FL
Phil
When I look into a basement system over the winter or early spring I hope, I will look at that among other options. My take on what I have from digital amps, including high end ones, is that they tend to work well with very non-demanding loads. As soon as they see something just a bit complex they tend to have trouble more so than other things in the same price class. It may be rumor, but I have heard that in the next Bryston newsletter (which will be available online) they may be including a mini-white paper on their take on digital amps as apparently they have been asked when they will make them by various parties.
Lee Scoggins
Atlanta, Georgia
Lee
Phil, thanks for the heads up. I will look forward to reading that paper.
kevitra
I had the 2000 and 3000 in my system at the same time. They sound the same to me (which was good, IMO).
From Sony's PDF, the 2000, 3000 and 5000 all have pretty much the same internals, so I would expect them to sound the same.
DarrylM
They don't make digital switching amps because they sound better. They make them because they are cheaper and smaller. Digital amps are more efficient and run cooler, which means smaller heatsinks, power supplies, and so forth. They actually go through a lot of trouble to make them sound as good as solid state amps.
Concluding that the 2000ES sounds "like crap" after listening to it after no burn-in is foolish. Reporting this on a public forum is irresponsible.
Lewis Besze
Hey, he just voiced his opinion.Would you be this "angry" if it was positive?
Anyone who takes these "heard this product at the dealer" threads seriously,is missing the points of these threads.;)
LanceJ
Electronic "burn-in" is unproven and in my opinion it is actually related to becoming accustomed to a new component's specific sonic personality. The same thing happens to anyone that has attended college--their first meal at the dining hall is a nauseating experience, then mysteriously by mid-terms it's "YES! they're having meatloaf tonight--mmm mmm good!!!." :)
Anyway, can anyone elaborate on exactly WHAT sounds bad about these types of amps? Because I have a feeling these amps might be taking over the mid-fi class in the next five years if they actually sound decent. This thread sounds similar to that previous Panasonic XR-45 thread where everybody was guessing, or relaying second-hand information about the sound.
LJ
DarrylM
I can't speak to the Sonys in particular, but apparently digital switching amps (class D) often have poorer bass response and even greater difficulty in producing higher frequencies because of the extremely high switching rates involved (since the switching frequency can be 1,000 times higher for a 20 kHz signal than a 20 Hz signal). This difficulty is why digital amps have been more common on powered subwoofers in the past, though many manufacturers have made some progress with full-range digital amps over the past few years.
Lewis Besze
It's funny you say that it has poorer bass,as this type is very popular with powered subs, as you pointed out including Velodyne.The type being used here,and most other digital amps are different[not class D],but I didn't educate myself as how exactly they work,I just know they're not the same.
Brian L
The latest Audio Critic has a detailed engineering review by David Rich of Sony AVD-S50ES that uses a digital switching amp(IIRC), an overall review of the same product, as well as a great piece by Tom Nousaine about the need for break-in (or lack thereof).
Larry, I don't think Tom would share you point of view on break in for electronics.
BGL
AlohaTiger
