ron feinberg
- Oct 15, 2003
Hi, I just purchased a new Sharp DT-200 Front Projector. On a previous post I explained that I am stepping up from an older Sharp XV-H37U projector I have been using for the past 5 years.
On first demo, the DT-200 is AWESOME in comparison to the H37U! It is MUCH brighter, and much more detailed. The colors are amazing. I am very pleased.
My only problem is with an issue that I am seeing on this new projector that I was not on the old one.
On certain video sources, including DVD and some digital cable channels I can see a "ghost rolling line" that slowly moves up the screen in a repeating pattern. It is very faint, and moves pretty slow. But it is definately apprant, and a big distraction. I switched back to the old projector, and I cant see these lines at all. I don't know how to better explain it except to day that it is a rolling horizontal line that moves from bottom to top, that is very faint...sort of a ghost image. It does not do it on every video source that I have watched...or perhaps on certain channels or sources, it is less obvious to see.
Could this be the projector? Some kind of sync/phase setting (but i'm just using a composite video connection right now) or some other setting? Or is it that this new projector is just so bright and sharp that it is bringing out something that was always on my system, but i just couldnt see.
If it is my video sources, then what would you do about this? I have good equipment, all hooked up with monster cables. My Home Theater Receiver is top notch...I am real surprised to see this happen on DVD's. If it was just cable TV, I would think it was the tv signal. But the DVD's show it worst of all (perhpas due to their high resolution and clarity?).
Any advise would be appreciated.
Thank you.
Ron
Thank you.
Ron
