New Receiver
Discussion in 'AV Receivers' started by TravisKH, Jan 2, 2004.
  1. TravisKH
    TravisKH Auditioning
    Sep 13, 2003
    12
    For instance, let's say I have a philips HTIB, can I get, say, a new sony receiver and still use the same speakers? Are there concerns with how many watts or so on? Thanks.
  2. ChrisHall
    ChrisHall Auditioning
    Dec 27, 2003
    14
    as long as the reciever can handle what ever ohm the speakers are rated at, and the speakers can handle the wattage, i can see no ill effects from doing so.
  3. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Yes you can and it usually shouldn't be a problem, especially if the speakers in the HTIB are just satellites... unless they have a very low Ohm rating.
    Also, I would avoid the lower-end Sony's just from personal experience.
  4. AaronJB
    AaronJB Second Unit
    Nov 2, 1998
    460
    As long as they don't have any proprietary speaker connections (something other than normal speaker wire - I've seen some HTIB sets w/plugs for connectors, which wouldn't work), they should work.
    Instead of a Sony receiever, you might want to consider Panasonic or Pioneer models.
  5. Andrew O'Brien
    Andrew O'Brien Stunt Coordinator
    May 27, 2002
    97
    I have owned a Pansonic SAHE100 for the past week, seems good so far. It replaced a 10 year old Sony Surround sound receiver. The old Sony receiver had a few more sound tailoring controls (bass, treble, and mid ) than the Panasonic, but other than that I'm happy to be in the Dolby Digital and DTS arena, the Panasonic can be had for around $220 if you look around. Low-end, but plenty good for me!
