New projector
Discussion in 'Displays' started by Rick Westfall, Mar 29, 2005.
  1. Rick Westfall
    Rick Westfall Stunt Coordinator
    Dec 8, 1998
    220
    My HT construction question in the other forum has turned into this topic, so I figured I should start the topic here.
    I'm looking at one of two ideas. Home Theater Store has the 65" Diamond Series Mits on sale for $2999. As you probably know, that's the top o' the line with integrated HDTV tuner.
    If my budget stays the same, I need suggestions on where to start looking at projectors. I've considered a DIY screen, but if my lazy streak hits I'll probably just go ahead and buy one. So, assuming a decent screen and projector...what brands should I begin looking at for $3K.
    Rick
  2. Jon Oliva
    Jon Oliva Agent
    Dec 7, 2003
    46
    I'm looking in the under $2500 price range and two new dlps are just hitting the market: the Toshiba MT700 and the BenQ 7700. They are 1280x720p DLPs with the HD2+ chip. 1000 lumens and >2000:1 Contrast ratio. I would check them out. www.projectorcentral.com has some decent info/commentary to get started.
  3. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Rick, if you want HD, you should also check into the Sanyo Z3, Panasonic 700, Sony HS51(this may be over $2500).
  4. Jon Oliva
    Jon Oliva Agent
    Dec 7, 2003
    46
    Those are three good options from the LCD world. The sony should definately be over $2500 I think.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Guys, let's talk about this subject here in Display Devices. As for sending someone off to AVS Forum, why not direct him to appropriate or related threads here at Home Theater Forum?
  6. Rick Westfall
    Dec 8, 1998
    220
    Oops sorry about picking the wrong forum. Thanks for the redirect.
    Rick
  7. Jon Oliva
    Jon Oliva Agent
    Dec 7, 2003
    46
    Jack - sorry about that, it was kind of rude of me. I was only trying to help, and I hadn't seen many detailed PJ threads over here at first glance (haven't checked the board in a few). My bad.
    Edit - fixed for ya [​IMG]
  8. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Sharp XVs2000, Sanyo Z3, Panasonic L700U, BenQ 7700 all native 720p for starters.
  9. Craig W
    Craig W Second Unit
    Jul 28, 1999
    445
    Some great deals going on out on the web for the Sharp Matterhorn DLP units. The DT-300(short throw) and XV-Z200(long throw) are showing up online for south of $1900. These units originally sold for around $3k.
    Granted they are only EDTV, but don't be too quick to discount these units. There is not a huge difference between 576p and 720p. Plus these DLPs have lens shift making set-up easier which is not featured on any of the new low-cost DLP units.
    700 ANSI Lumens
    2000:1 ON/OFF CR
    LENS SHIFT
    5x 6-segment CW
    DVI-HDCP
    16:9
    210W/168W 4000hr bulb
    Sleek looking design (not your typical projector box)
    These are great bargains right now. I bought my DT-300 in September for $2600. Sure wish I would have waited [​IMG]
  10. rin
    rin Stunt Coordinator
    Oct 24, 1999
    233
    The Sony HS51 is a great projector and can be found for under $ 2,800 on line. If you pair it up with a Carada screen you won't be too far over your budget. The DLP's are very nice too but make sure you see one in action before you buy. The rainbows bothered me on the Optoma H77 I demo' d. Other than that it had a good picture. My HS51 is on it's way and I'm probably going with the Carada brilliant white 96" diag. screen. I can't wait!
    Good luck with whatever you decide to go with and keep us posted.
