New Polks
Discussion in 'Speakers & Subwoofers' started by Kevin_Welch, Jun 3, 2003.
  1. Kevin_Welch
    Kevin_Welch Agent
    Jan 30, 2003
    31
    I just got my new polk audio lsi15's and was wondering what owners of these found to be the best placement? im using them as my fronts. is angle important?
    TY
    K~
  2. Alex F.
    Alex F. Second Unit
    Aug 29, 1999
    377
    In my system and room, using LSi-25s, the best soundstaging, imaging, and tonality are achieved when the speakers and sweet spot make an equilateral triangle, with the speakers toed-in and aimed directly at the listener.
    The LSi speakers need a good bit of run-in time to achieve their maximum smoothness and best performance. Mine needed over 100 hours of use (I played them, unattended, at moderate volume for several days).
    Happy listening!
  3. Rick Faldo
    Rick Faldo Stunt Coordinator
    May 10, 2002
    58
    ....and plenty of power to drive them....
    Rick
  4. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    Location and toe-in are very important with the Lsi series. I've had to compromise a little with regards to toe-in in order to get the best possible sound for 2 channel music and HT use. Not having installed spikes allows me to slide them around a little bit.
