New plate amp question
Discussion in 'Home Theater Projects' started by Scott Miller, Apr 18, 2005.
  1. Scott Miller
    Scott Miller Agent
    Sep 9, 2001
    28
    I've got an Infinity BU-120 150W sub with a blown amp module that seems to be no longer manufactured. The rest of the sub is in excellent condition. I know that if I buy a new amp from PE, I'll have the problem of finding one to fit perfectly or covering up the hole left by the old one. If I opt for using it externally, can't I just leave the old one there and just have the two speaker wires coming out of a small sealed (silicone?) hole?
  2. Mattak
    Mattak Stunt Coordinator
    Dec 15, 2003
    247
    Yes, you could do that. Surely you could make a new one fit, though. Cut the enclosure if it's a bit bigger, or make an insert out of MDF if it's smaller...
  3. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    It's likely that the amp contains custom circuitry specific to the Infinity driver. As a result replacing it with a generic amp may prove to be a disappointment
