New PC is up!
Discussion in 'Archived Threads 2001-2004' started by Eric Samonte, Mar 24, 2002.
  1. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    Ok...I'd like to thanks u guys for helping out. I'm glad I listened to u guys to build it rather spend a whole lot more buying finished. Here's my set-up...
    P4 1.8 AG
    Asus P4B266
    512 PC2100 DDR RAM
    Maxtor 60GB 7200RPM HDD
    Chaintek GeForce3 Ti200 64MBDDR
    SB Audigy Gamer
    Samsung 16x DVD
    Lite-On 32x CDRW
    Klipsch 4.1 Pro Media
    Windows XP
    I only have one nagging problem though. The Audigy card can't seem to output sound at the rears. If anyone has an idea on how to fix this pls chime in. Also, I noticed that the spkr settings on XP doesn't work. I set it on surround or 5.1 and its all the same. Thing is..I set it to no spkrs at all and I still have sound.
  2. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    make sure you have downloaded the latest Audigy XP drivers off of the Creative website. I believe the drivers that XP installs automatically don't have 4-channel support.
  3. Rob Varto
    Rob Varto Supporting Actor
    Mar 5, 2000
    711
    Kelley is right. I had the same problem. Once the updates are d/l and installed, make sure you properly setup your system within the Creative software... ie. make sure you designate that you have a 5.1 system (or what have you) and adjust the speaker volumes accordingly. My fronts were MUCH louder than my centers and rears the first time I used the Audigy.
  4. Eric Samonte
    Mar 31, 1999
    1,318
    The Audugy problem has been rectified. I read at another forum that one should install first the original drivers then upgrade with the new XP drivers. It works great now!
    Brett..total cost with a Samsung 19" 955DF is $1800...give or take a few bucks.
    Now..my next project would be trying to overclock this thing...to maybe 133 FSB.....2.4 GHz here I come!
  5. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Thanks Eric!
    It sounds like one heck of a system.. I was just curious
    about the price because I haven't priced out individual
    components and rather than build my own (which I can) I
    decided to go prebuilt. I had people tell me that I could
    have built the system for $700.00 and I said they were nuts.
    If they could build a system similar for $700 they must
    be using refurbed items! [​IMG]
    Great job with your setup!
