New Paradigm Setup- Help1
Discussion in 'Speakers & Subwoofers' started by dennis.cr, Aug 29, 2005.
  1. dennis.cr
    dennis.cr Auditioning
    Aug 29, 2005
    I will soon be buying a set of Monitor 7's, and a CC270 or maybe CC370 center. For now, I am going to skimp a little on the rears, what do you think would be better, a pair of Cinema ADP's or Atoms for the rears. The costs are roughly the same for either pair, but I am unsure what would be the better option.The way my tv is setup, the rears have to be mounted on a wall that is directly beside both sides of my couch. Setup is almost only for movies. Also, do you think the CC370 center over the CC270 is a worthwhile upgrade for the money? Also, what is a decent discount from sticker price? I have been offered the following:
    Monitor 7's
    CC270
    Cinema ADP
    $1250 Canadian. I think this is about 18% off. Is that decent, or do you think there is more room to bargain?
  2. AlanZ
    AlanZ Screenwriter
    Sep 15, 2002
    1,336
    Id go with the ADPs in back and the 370 center.....just my $.02
  3. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    I would go with the CC370 and Atoms. Unless you have the proper room setup the ADP's may not integrate well. As far as your discount 18% is good, but there's no harm in trying for more.
