New OM-200 Sub
Discussion in 'Archived Threads 2001-2004' started by SteveDev, Aug 22, 2002.
  1. SteveDev
    SteveDev Agent
    Jun 24, 2002
    44
    Does anyone have any specs/news for this sub. Went to my dealer today and he told me he'd likely have it in next week. All he could tell me about it is that it had a 350 watt amp with peak power of 800 watts.
    These are replacing the BPS series. I'd imagine the 200 is the replacement for the BDP-150. Although he said the retail will likely be close to $1500. Wow.
  2. SteveDev
    SteveDev Agent
    Jun 24, 2002
    44
    Sorry, forgot to mention the make of the sub was Mirage in case some where wondering ...
  3. SteveDev
    SteveDev Agent
    Jun 24, 2002
    44
    Just got an email from Mirage which answered my own question! Want to get some opinions on the specs below from some of you experts out there if possible!
    The OM-200 replaces the BPS-150, here are the specs:
    Model OM-200
    System type Omnipolar Subwoofer
    Amplifier type Discrete MOSFET Class A/B
    Power output 800 watt dynamic peak,200 watts continuous
    Woofer Two 8” Titanium Deposit-Polypropylene Hybrid
    Magnet Size 28 oz.
    Voice Coil Diameter 1.5”
    Frequency response 20Hz-120Hz +- 3db
    Phase Control Continuously variable from –180 to +180
    AV Switch 0/+3db
    Variable low pass filter 40Hz –120Hz @ 18 db/octave
    Inputs Low level, crossover bypass, high level
    Outputs high level
    Dimensions inches: 16 1/4 x 18 5/8 x 15 1/2
    cm.: 114.2 x 47.4 x 39.4
    Finish Black High Gloss, Cherry
    Weight 70 lbs.
    32 kg
