hawkeye12345
Grip
- Dec 29, 2008
- Dennis
OK - so lots of questions in my first post and I'll do as much research on each subject as possible but I would appreciate any input that this forum may give.
Here's my setup:
TV - Pioneer PDP-5080 - fully HDMI compatible 1080i
DirecTV - HD DVR (don't know brand, sorry)
Denon 4806 (not the CI) but will buy upgrade software if it makes sense
Speakers: Up for recommendations at this point but looking to go 7.1 in-wall speakers. Will do tower speakers but keep in mind that the only exposed equipment at that point will be the speakers so aesthetics would be important. Any recommendations here?
Add'l Accessories
Oppo DVD player - HD
PS3 for Blu Ray and gaming.
HDMI connections for all components - probably using Blue Jean wiring based on reviews. Again based on research it appears that HDMI is the best way to go for audio / video connections, correct?
The whole setup will be in a fairly small room that is about 15 feet deep and 12 feet wide with TV wall mounted and ALL accessories including receiver will be located in equipment closet that is 8 x 8.
Questions:
First what speakers would you recommend?
Next: 7.1, 6.1 or 5.1?
Next: Are the connections being used (HDMI) the best?
Next: Do I need an amp? If so, which one?
Next: Do I need a computer hooked up? I'll be honest, I have no idea what a computer would do in this configuration so any help on this subject would be appreciated.
Next: More than likely running wireless security video to the utility closet to be ran to TV for easy monitoring (two children under 3 years old).
Next: Are there any special considerations that I need to take into account when running the in-wall speaker wire? ie., distance from electrical cables, HDMI cables, from each speaker wire?
What am I missing? Is there some component that I left out that I need to have?
Thanks in advance.
Here's my setup:
Add'l Accessories
Questions:
Thanks in advance.
