Theoretically yes. I was only being cautious because I recently had a problem reverting to an old firmware w/a DVD-ROM drive. It had a beta firmware on it & refused to re-flash w/the original manufacturer firmware.
The firmware installed successfully without problems. I didn't have time to do a good check of things: had to go to work. Saturation level MAY have been raised, no big deal. Ringing in 720p is still there. Unable to use test patterns to check 1080i at this time, will do that soon. Setup menu and information overlay seemed the same. Didn't get a chance to check 480i or 480p.
Geeze....this completely screwed up my color settings. I just got through spending about 20 minutes with DVE, and it's still not right. Close...but not like before.
Haven't been able to detect any differences with any features.
After finally getting time to run DVE on mine I can say they have changed brightness, contrast and saturation. I've finally been able to set mine all back to 0. I had white crush with brightness at 0 or above and had to use -1 but not anymore.
I believe the LiteOn, with video adjustments at zero, is now the same as the Momitsu out-of-the-box. Just stating an observation. Both players look the same and great to me.
My brightness is now at around 75%-80%, where as before it was around 30-35%. If I calibrate my color first, I have to turn the tint up to around 85-90% (green) before it reads correct.....then, of course, the color is all screwed up.
I went from +1 to -1 on the saturation to try and get the color back in line....but no dice.
I've had problems with my system in the past with DVD players that output 0 ire...so I think that's the big issue. I agree with you, Wesley, that they've made the black level 'correct'. Bad news for me....unfortunately.
So, I'm very much NOT of a fan of this upgrade....especially since I can't find any FEATURES that have been changed for the better. (Like not losing your zoom setting when you change chapters).
I'll probably go back to 229 today.
If there is a big benifit I'm missing, please educate me.
The new upgrade includes some much needed functionality.
Subdirectory support in the file browser.
OGG Audio support
No more freezes on divx3. Quality is lower but compatibility is now excellent. Others have mentioned higher bitrates are also possible on xvid/divx4/5 too, and it adjust quality accordingly.
I watch pretty much zero DiVX stuff on my 2001, so anything related to that isn't an improvement for me. I'll email LiteOn support and see if they can provide a readme for reference on the beta.
