new IB response curve, uncorrected, no EQ
Discussion in 'Home Theater Projects' started by Rich Kraus, Feb 24, 2005.
  1. Rich Kraus
    Rich Kraus Stunt Coordinator
    May 3, 2000
    209
    I left the response curve picture full size to preserve the detail, the link is below.
    [​IMG]
    method:
    burned sine tones from NCH generator, 1Hz steps, 1-85Hz.
    red line is 70dB/60Hz baseline.
    utilized radio shack analog dB meter (stock)
    played tones in 1 hz steps, starting at 85hz working down (allowing 10 min cooldown after each 10 steps, just to be careful) and charted results in 1Hz steps.
    note that after baseline was set meter was moved to new location, and left for duration of test, hence -5dB reading at 60Hz.
    results here
    i have suspicisions the null at 67hz may be due to meter placement, i may retest another day when i have more time.
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    Hi Rich,
    The IB looks good. I assume those are some Stryke drivers right?
    I cant really make out that graph. If you want to you can throw them into this Excel worksheet:
    http://www.snapbug.ws/subtestmodel.xls
  3. Rich Kraus
    May 3, 2000
    209
    similar to the strikes.
    they are TC Sounds TC2+ 15"'s
    believe it or not i dont have excel installed on this machine. i think i may have it on the one in the other room, but my SO is doing homework on that one right now (do not disturb [​IMG] )
    basically the graph is one HZ/one dB step per square. 85hz on the right, with divisions on the red line every 5hz.
  4. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    whats the differance between them and the stryke?
  5. Rich Kraus
    May 3, 2000
    209
    the strike drivers are still available [​IMG]
    theres a couple mm difrence in the xmax, and a couple other minor diffrences in the other T/S's
    there pretty close...
  6. Jason Dalton
    Jason Dalton Stunt Coordinator
    Feb 20, 2004
    174
    With meter corrections, that response will be flat down to the limits of your measurement (13Hz). Very nice!
    Now see how loud you can get it to play at 10Hz. [​IMG]
  7. Ben Ven
    Ben Ven Stunt Coordinator
    Mar 6, 2002
    61
    Nice work!
  8. Rich Kraus
    May 3, 2000
    209
    chris white over at HTT was kind enough to adjust my figures (corrected for the RS meter) and turn them into a more readable plot:
    [​IMG]
    Some stats (corrected values):
    average = 67.9
    std deviation = 3.28
    thanks chris..
