New HTIB Setup Help
Discussion in 'Archived Threads 2001-2004' started by Brian Sokol, Feb 4, 2002.
  1. Brian Sokol
    Brian Sokol Extra
    Dec 29, 2001
    23
    Hi I just bought a Kenwood HTB 504. The vendor upgraded my receiver to the VR509. I also bought a Panasonic DVD CV51 changer. What are my options for connecting everything together? here is what I now have:
    Proscan 32" TV - no component jacks - only S Video
    VCR
    VR509
    Panny CV51
    Very confused about which cable goes where, what is Toslink and do I need it etc.
    thanks
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi brian -
    there's two different paths you can take.
    1. run all audio & video to the receiver.
    2. run audio to the receiver and video to the tv
    personally, i prefer to run everything to the receiver, then run only one video-out to the tv. this way, you can control and "switch" everything from one source (the receiver).
    others feel that, by running the video through the receiver first, that you will degrade the signal quality. i recommend you test and see for yourself.
    in order for your receiver to decode the dd/dts signal from your dvd player (don't forget to set it up in the dvd player too) you'll need either a digital coax cable or a toslink optical cable. note: use whichever you like better. some say there's a difference, other's say that's nonsense. you'll run the video out from the dvd player to either the tv or receiver, depending on what setup you decide.
    hope that helps some...if you have more questions just ask!
    [​IMG]
  3. Brian Sokol
    Brian Sokol Extra
    Dec 29, 2001
    23
    Thanks!
    So if I run everything through the 509 is this my setup:
    Toslink from dvd to 509
    Composite from dvd to 509
    Svideo out from 509 to tv??
    Do I run my vcr to the 509 or to the tv? Also if I want to watch a tv show with just the tv speakers can I do that without turning on the 509?
    I also posted this question in the Wires section and here is a suggestion i got there:
    Video
    composite video cable from the 509 output to the TV input.
    S-Video cable from the 509 output to the TV input.
    Composite video cable from vcr output to 509 vcr input.
    svideo cable from CV51 output to 509 dvd input.
    audio
    Left/Right audio cables from VRC output to 509 VCR audio input (the red and white plugs)
    TOSLink Optical cable from CV51 output to 509 digital1 input. Assign digital1 to dvd using the 509's menu system (look in the manual for info on assigning and using digital inputs)
    If your TV has audio outputs for external speakers, connect them to the receiver's TV audio inputs. Then turn off your internal tv speaker.
    run speaker wires to each of your 5 speakers. Run a cable from the subwoofer output on the 509 to the subwoofer input on the sub.
    Thanks Again
    Brian
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    correct...run everything to the receiver first, then run the s-video to the tv.
    if you hook up the tv cable from the wall to vcr to tv, then you should be able to watch the tv without having to turn on the receiver. the sound will "follow" whatever path your tv cable is running.
    the recommendation given will work, but it seems like you're running two video out's from the receiver to the tv. i don't see the logic in that...unless i'm missing something. you'll get better picture quality with s-video anyway, so you should always use that when possible.
    oh yeah...i'm assuming the receive will convert composite to s-video?
    you have some flexibility in how you want to wire the audio for the tv. i use my vcr as the audio-out source...that way i only have to run one set of audio-outs (from vcr) to the receiver. you can, if you choose, also run the audio-out from the tv to the receiver. that's personal preference.
    man...where's bob mcelfresh? [​IMG] he's much better at explaining this stuff...
  5. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
    Very few receivers convert S-video to composite. Many keep the signal paths entirely separate -- i.e., if a component send S-video to the receiver, the receiver will only send an S-video output. I don't know how the 509 handles it.
    M.
  6. Bill Catherall
    Bill Catherall Screenwriter
    Aug 1, 1997
    1,560
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
  8. Eric Walsh
    Eric Walsh Stunt Coordinator
    Jan 5, 2002
    220
    Brian said his HTB 504 came with an upgraded VR 509. I had heard mention of this somewhere else as well. Is this common practice now?
    Sorry this doesn't pertain to the setup question.
    -Eric
