Andrew Hornfeck
- Sep 21, 1998
I've been a HTF buff for years and am planning a real HT in the basement of a new home I'm seriously planning. I've racked my brain and have decided on a FIXED screen for a FPTV. I considered a roll-down and recessing my 7-year old 45" MITSU into the wall for off-DVD viewing; but reconsidered after realizing the additional screen cost alone would buy two replacement bulbs!
The room could be up to 15x24 and I'm considering placing the front wall at 20' to allow for household storage in the 4' behind it. Yes? No? Acoustically, is there a problem with either? The ceiling is stated to be 9'. Should I stick w/steetrock or opt for acoustic tiles instead?
I'm planning on using either the Sony 10ht or the JVC G11 with a 52x92 screen. I'd like a CLEAN installation withOUT the equipment showing. I may use a side wall-mounted eq rack but don't want the speakers standing right there. So I thought about in-wall units -- possibly NILES, Boston Acoustics or Phase Technology.
A local installer suggested NOT using the in-wall variety in favor of an acoustic wall (basically speaker cloth) with the equipment located behind it! This allows the use of ANY speakers with the emphasis on future upgrades. I don't see myself doing much of that considering the cost of the house with HT room, equipment, pool, Jacuzzi, etc...
I'd like opinions on IN-WALL speakers -- like? Dislike? Experience? If I don't do the in-walls then I'd most likely keep my current set of Radio-Shack specials until I found a MATCHED set I like for around $1200 - 1500 for the set of 5. I'd like to keep my Yamaha YST-160 & RXV-995 receiver.
I've got questions on getting a HTPC instead of a DVDO Iscan to "process" the video. Thoughts on THAT?
It was ALSO suggested to abandon the concrete floor and build it up w/2x4's and plywood to enhance the bass transmission. It would cost a couple o' hundred and having the contractor SINK the floor the 4.25" difference. Do it or pass? Opinions, please! H E L P !!
Andrew
Andrew
