Todd Henry
- Feb 4, 2002
This weekend I got the Kenwood HTB 544 system and the Sony 5 disk changer DVD (600). I have gotten it combined with my TV and Direct-tivo sytem, plus the center channel and fronts wired with the provided speaker wire. The digital sound is connected from the DVD and TV receiver. So it is functional and better than what I had before, which was nothing. Now some questions for the experts.
1. The Center Channel is on top of my entertainment center which is about five feet high. I know that the center and fronts should all be the same height. Since the center is horizontal and the fronts are vertical, should the bottoms or tops be lined up or should the middle of the fronts be the same height is the center? Also, how would I angle the front down towards my listening position.
2. My room is very long and narrow. The listening position is on the back wall. I do have a wall to my right that I could mount one of the surrounds. Would I be better to do that and get a stand for the other surround speaker. Or should I just get 2 speakers stands for the surrounds. Or could I mount them on the wall behind me and get speaker brackets that could angle the sound in the correct direction.
3. Speaker wire. I went to Best Buy and bought some 16 gauge wire. Is higher or lower gauge better? How poor is the speaker wire that Kenwood provided?
4. A stupid remote question. When I try to change the video input via remote, it only cycles through AV/Aux and Video 1. However, my TV is on video 3 and the dvd on video 2. Did I accidently do something to the setup. Wow is it a large remote. Also, it appears that I need to point it almost directly at the receiver. Shouldn't it work better than that?
Thanks in advance for your help.
Todd
Todd
