SimonKing
- Jan 31, 2002
I just got my first home theater set up and had a couple of questions about configuring the audio. I'm not entirely sure I know what I am doing so hopefully you guys can help me out.
I have a Sony DVP-NS400D DVD player, Yamaha HTR-5440 receiver, Paradigm Cinema Series fronts and rears, Paradigm CC-70 center, and the Paradigm PDR-10 subwoofer. I'm using the Video Essentials DVD for the pink noise tests.
First off, I can't see any way whatsoever to adjust the level of the front speakers in an effort to reach 75db with my SLM. I was going through the pink noise tests and thought I was supposed to adjust the level of the front speakers, but there doesn't appear to be any way to do it with the receiver or even in the setup of my DVD player. So, I have to ask if they can even be adjusted or are they not supposed to be adjusted? Or am I missing something major here?
My other question is with regards to the sub. I adjusted the "subwoofer level" on the back of the sub so that I got 75db without any trouble. I didn't know though what the "subwoofer cutoff frequency" should be set to. It goes from 50Hz to 150Hz. Anyone have any advice on this or can tell me what it should be?
Thanks for any help and advice you can offer!
