New HP Digital Entertainment Centre
Discussion in 'Computers' started by Mike Boniferro, Oct 19, 2004.
  1. Mike Boniferro
    Mike Boniferro Second Unit
    Aug 21, 1999
    273
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    My only real beef with it is that it uses onboard audio. While the Intel HDAudio is supposed to be really good, I'd want a separate card in an HTPC. Additionally, using onboard audio means the audio is eating up some CPU clock cycles which you really can't spare too many if you're using it as a PVR.
    Also, I'd want another 512MB of RAM, but that can be added pretty cheaply.
  3. Mike Boniferro
    Aug 21, 1999
    273
    Could you add a seperate audio card?
    I'd like it to have a component in so you could use it as an HD PVR.
  4. SethH
    Dec 17, 2003
    2,867
    You could certainly add a separate audio card. I'm not sure what all problems you'd have getting it set up around the built-in stuff, but I don't think it'd be too much trouble.
    ATI, among others, offer HDTV PVR cards that will work with an HDTV antenna (the ATI model comes with the antenna), so you could always add one of those.
  5. Mike Boniferro
    Aug 21, 1999
    273
    But if you don't have access to any (or limited) OTA HD, then you'd still need a way to feed it an HD signal.
  6. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    No such thing as consumer HD component capture card yet. [​IMG]
  7. Mike Boniferro
    Aug 21, 1999
    273
    It seems like that would be a no brainer for HP to include in this package... if it's supposed to replace your PVR, and a lot of people now have HD-PVR's... well, you know [​IMG]
