Patrick Larkin
- May 8, 2001
Hello - I am having a house built over the summer and am distressed about how I am going to set my existing home theater equipment. My current house has hardwood floors and area carpets so I can run speaker wire under the carpet to the various locations. the new house will have wall to wall carpeting in the location of the family room. I have an opportunity while the walls are open to have speaker wire run, at least.
So, can someone help me with what I should tell the builder I want? If I tell the builder I want the ability to put speakers in the 4 corners (more or less) can they run speaker cable and then terminate it in some kind of jack? Or would they have to dangle it out from the walls? I'm not sure how I will handle the center channel or the sub since I have no idea where the stuff is going to go until its built.
Eventually, I plan on moving the whole system into a finished basement so I don't want to go overboard. I just want to make cables has hidden as possible.
