new home theatre questions
Discussion in 'Home Theater Projects' started by paul_austin, Sep 6, 2005.
  1. paul_austin
    paul_austin Second Unit
    Jun 16, 2002
    276
    2
    Ok soon in the new house we're moving into I'll be able to do whatever I need to the basement to make it my home theatre. First question is about my cement floor...should I go with carpet or hardwood tiles? Construction will be way way off so i have plenty of time to mull stuff over.
  2. Dan_J_H.
    Dan_J_H. Stunt Coordinator
    Oct 18, 2002
    131
    I'm going with carpet over Dri-Core panels. The Dri-Core panels are about 2'x2' wood panels with a plastic bottom with raised cleats to allow air movement under the floor so your carpet stayes warm and dry. I have my panels down but no carpet yet. These panels give the floor a more "upstairs-like" feel. I bought my Dri-Core panels from Home Depot.
    Dan
  3. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    Although many people will recommend carpet because of accoustical reasons, hardwood is fine. Our ears/brains compensate for reflections from the floor on their own.
    Hardwood tiles directly on cement might be a little...hard... and uncomfortable to walk on. I used carpet and pad, (over a wood subfloor) so I can sit on the floor and watch if I want too, or walk in the room barefoot and still be comfy. It also stays warm in the winter.
  4. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    We recently switched our a carpeted floor for wood, and the wood is definitely more “live.” If this is a dedicated room, I’d go with carpet. Basically, any time you put a large soft covering over a large hard surface, reflections are reduced.
    Wayne A. Pflughaupt
  5. chris_everett
    Jul 20, 2003
    403
    I should add that if you have a hardwood floor, you _will_ want absoption elsewhere in the room.
