cryo75
- Jan 26, 2011
- Ivan Debono
Hi all,
I'm from Germany and new to this forum and also new to home theater
Anyways, I have finally managed to clear a room in the cellar for my home theater. Currently the room needs to be refurbished. New plasterboards will come on one wall and new sockets placed on each wall. The room is about 2.7m wide by 4m long and has a height of about 2.3m. 1 wooden door leads to the room whilst 1 glass door leads out to the garden.
My original plan was to paint 3 walls and the ceiling white whilst the wall were the TV will be placed will be covered withing beige facing stones. The floor will have rustic terracotta tiles. I was planning on having a 50inch TV, HD sat receiver, Xbox360 incl. Kinect and a Blu-Ray player.
I was thinking of getting the Philips 52PFL5605H TV and the Philips HTS5580 5.1 Blu-Ray system. One thing that I don't want to have is cables running around and along walls!! So I need to make holes in the drywall so the cables will go through.
After doing further research, I was thinking of using a projector and silver screen. The problem that I have with projectors is that most have just 2 HDMI connections and a lamp lifespan of about 3000hrs. I would need 3 HDMI connections to connect my equipment to it.
As I'm currently in the early stages, I have some questions which I hope you guys can answer!!
1. Should I paint the room in a darker color instead of white? (If I have a curtain in front of the glass door, the room will be quite dark just the same)
2. If I get the above HTS system, and as this system won't have long cables, can I use my own speaker cables that will be behind the dry wall?
3. Should I place 4 or 6 small lamps in the drywall ceiling or just 1 lamp in the middle of the room? I would encounter this problem if I would place a projector on the ceiling at the back of the room.
Hope someone answers my initial questions. I'm sure I will have more later!! And if pictures are required, I can upload those too
Ivan
Ivan
