New Home theater builder needs help
Discussion in 'Home Theater Projects' started by ShawnN, Sep 7, 2003.
  1. ShawnN
    ShawnN Auditioning
    Sep 5, 2003
    5
    I'm a new home owner with a passion for home theater but don't know were to start. My room is in the basement 9'6"W 17'10" L & 7'8" H. The rear, left & front wall are concreat, the right wall needs to be framed. I and Planing to use a 6x2 with staggered studs with some sort of insalation.
    My speakers are Infinity RS5' for the front, cc3 center D box 12" sub & RS2 for the rears (11"D 13"H 8"D.)To keep costs down I would like to keep my existing speakers. I also would like to upgrade to a 6.1 but the room is so small and my rears so large I'm not sure if it would make an diffrence
    I am planing to get a projector but don't know how big a screen to get with that size a room. useing the 5ths rule for speaker placement Maybe 69" or so?
    Any recomondations would be great.
  2. Larry Lopez
    Larry Lopez Auditioning
    Sep 6, 2003
    2
    Dear ShawnN,
    Have you thought about using in ceiling or in walling speakers for the center rear? I hire this company called My Connected Home, in CA to design and install my Home Theater. They did a great job on my Home Theater Room. They also got help you in selecting a screen for you. They probably would recommend you a Stewart Screen.
    You can contact this gentleman name Willy @ My Connected Home through his e-mail: [email protected] or you can call him @ (909) 972-6061
    Hope my info. would be helpful.
    Larry
