podbuster
- Dec 3, 2007
- Andrew
Hello everyone,
I'm relatively inexperienced when it comes to home theater solutions. I realize I should be consulting with an HT professional, but I would much prefer to do this job myself, with some help by experienced people such as you.
I have a $15K budget for the entire solution. I believe that should be enough to give me excellent results!
The room is rectangular in shape, in the basement, on concrete, and will be used as a home theater and games room. It's 30 ft long and 16 ft wide. 14 ft of the length is dedicated for the theater, including seating. I plan to put in thick underlay and nice carpet. I can't put in a subfloow without sacrificing the already minized ceiling height (~7.5ft) We are having a gas fireplace installed and the design calls for the TV to be mounted above the fireplace on the 16ft wall. We are very aware that we want the tv as close to eye level as possible, and we also know about the warnings of tv's over fireplaces. We have some strategies in place, such as a mantel, to divert heat away from the tv. I am getting R40 insulation on all interior walls and in the ceiling. I'm also getting sound bar installed on the ceiling. Wiring will be done through conduit when possible. A dedicated circuit will be provided for just the components.
I'm looking for 7.1 surround sound and a 52" LCD. The front left, right and center speaker can be on wall or in wall but cannot be on stands. The side left and right speakers can be in wall or on wall. The rear speaker must be in ceiling. I know the ceiling mounts are not optimal, but we do not want any speaker stands.
Based on the research I have done thus far, I have come up with the following:
- 52" Sony Bravia KDL52XBR5 LCD
- Sony ES STRDA5300ES A/V receiver
- Sony BDPS500 Blue-ray disk player
- XBOX 360 (already owned)
- XBOX HD DVD
- Speakers, including sub - Still not sure but have been looking at Tribes from Totem acoustics (they are very expensive - perhaps too expensive)
- Media center (maybe)
I would be interested in hearing feedback on this setup, including suggestions for a speaker system as well as any additional tips you can provide.
Thanks in advance!
- XBOX HD DVD
Thanks in advance!
