New here, first post. (1 Viewer)
Steve Z
Steve
Greetings,
My girlfriend bought be this Yamaha - 5.1-Channel Home Theater Speaker System - NS-SP7800PN for a Christmas present.
The specs say the speakers are all 6 ohms, but the Yamaha receivers such as Yamaha - 550W 5.1-Ch. A/V Home Theater Receiver - RX-V463BL are 105w x 5 at 8 ohms.
Why would the same company list specs for 6 ohms on speakers but 8 ohms for the receiver/amps?
Will that receiver work ok with those speakers?
What is 105w at 8 ohms when presented with a 6 ohm load?
Recommend a different receiver? Price range $200-400
Thanks in advance.
Freddie Ross
It will work fine. Companies generally rate the output at 8ohm because that is what most speakers nominally run at, but most are able to handle a 6ohm load, it just may have to work a bit harder. If you notice it going into protect mode at normal volumes then you should be concerned, but it should work fine. Enjoy the new system!
Edit: Actually, I just downloaded the manual for your receiver, and there is an impedance setting (which supports 6ohm speakers). You should be safe...
brettjv
