New HDTV, mixed opinions. (1 Viewer)
GarenSinaii
Hi guys, well I went ahead and got an HDTV today with a Progressive Scan DVD Player.
I got the Samsung 30" HDTV Monitor (TX-P3064W) and Panasonic DVD Player (DVD-S27S) DVD player. I bought component cables and got my Home Essentials Calibration disc.
I enabled 480P on the DVD player, and after calibration, I just don't see a big difference that HD has to offer. It looks no-where near the quality of the programming at the store(so I assume DVD's aren't at that level yet). The picture is grainy, and a little soft so Im pretty upset over that.
Xbox, I have that hooked up also with component cables, I enabled 480P and 1080i in the Setup, and I also have mixed opinions. Sure it looks good, but it doesn't really amaze me. Im still tweaking around with the calibrating, but as of now I just spent about a grand and I'm not too happy yet. What do you guys think?
Will d s
DVD's are not exactly high def They are only 480P if they had a 1080i/p or 720p source in the store it will definitely be a better picture. You should try to set it up with some HD sources with an over the air HD antenna or through your cable/satellite company.
Aaron H
480P DVD images should look pretty much the same on your new HDTV as they do on my old 27" Sony Trinitron. Like the previous poster said, you need to see some HD images.
GarenSinaii
Well, I actually went ahead and got a Sony KV30HS420. Immediately everything is much clearer, such as the Xbox main menu. Im going to calibrate the set right now.
Gary SI
Do you find that a 30" TV is large enough ?
I know that the Sony does 720p is that why you swiched ?
Do you miss not having PiP ?
Gary :D
GarenSinaii
Yes, the 30'' is defenitely large enough for my bedroom. I don't miss not having PIP because my old Sony Wega didn't have PIP either.
Robert Cowan
good choice on the sony. i finally got my 34" in the other day. i have been messing around with setting and service menu codes, and its looking good. im going to wait until the tube burns in a bit before i really fine-tune it though.
i had a panasonic 36" analog tube tv, which was a decent tv. i had it full calibrated and setup. i noticed an immediated improvement in dvd's over that tv.
of course, hd will look even better, but an HD capable set should even look better with just dvd too, imo.
Robert Cowan
the service menu is all the stuff sony doesnt want you to mess with. you can do scaling of the image, positioning, and more importantly, individual color adjustments. for instance, if you just have too much red (red push), but adjusting the tint give you too much green, you can go into service menu and JUST take out red alone. stuff like that. i think in the sony you can even adjust individual black and white levels, and even tweak the DRC etc... its not for the weak of heart, but there is a reset mode if you completely screw up your tv.
Allan Jayne
I would be very careful with service mode even if there is a reset. The reset may put the TV into pre-factory settings as opposed to the "factory settings" by the factory calibrators just before shipment.
Write down the original setting before making a change.
Also, going into service mode may void the warranty, depends on the terms of the warranty.
Video hints:
aotorusxwxr
