New Hard Drive, Will it work?
Discussion in 'Archived Threads 2001-2004' started by Peter McDonald, Dec 25, 2001.
  1. Peter McDonald
    Peter McDonald Stunt Coordinator
    Jul 24, 2001
    204
    I'm thinking about upgrading my 6.4GB hard drive to a 60GB 7200RPM Western Digital drive.
    My current specs are:
    -Celeron 400MHz
    -288MB PC100 SDRAM
    -not sure what the motherboard is, but it uses the Intel 810 chipset
    -Win98SE
    Will I have any trouble with the new drive? Will my current configuration support it?
    Peter
  2. JohanK
    JohanK Second Unit
    Jan 22, 2000
    478
    It should be fine except that I doubt your mobo can support ATA100 but probably only ATA66.
  3. Peter McDonald
    Jul 24, 2001
    204
    I didn't think it could support ATA 100 [​IMG]
    Anyways, do know how I can find out what motherboard I have? Any program I can download? I checked the manual, but it doesn't say anything about it.
    Peter
  4. Benny G
    Benny G Second Unit
    Sep 5, 2001
    250
  5. Peter McDonald
    Jul 24, 2001
    204
    Thanks Benny. I ran the program and this is the some of the info that showed up:
    Intel Corporation Whitney System CR Board Revision A0
    Board: Intel Corporation Whitney System CR Platform
    BIOS: Phoenix Technologies LTD 6.00 10/09/1999
    32 kilobyte primary memory cache
    128 kilobyte secondary memory cache
    Standard Floppy Disk Controller
    Intel 82801AB Bus Master IDE Controller
    Primary IDE controller (dual fifo)
    Secondary IDE controller (dual fifo)
    Any of that make a difference? Also, will I be able to use the existing IDE cable for the new drive, or do I need a special one?
    Peter
  6. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    To use ATA/66/100 you need an 80-wire IDE cable. The drive will work fine with a standard 40-wire IDE but you wont get the extra bandwidth.
    However I'm not sure your board will even support ATA/66.
  7. Peter McDonald
    Jul 24, 2001
    204
    How/where can I find out if it supports ATA/66?
  8. Peter McDonald
    Jul 24, 2001
    204
    I opened up the case today, to have a look at the motherboard diagram (strange place to put it... wish it was in the manual). Anyways, it's titled CD656M-WH/WL
    Does that mean anything?
    Peter
  9. Jeff Kleist
    Dec 4, 1999
    11,267
    Rob, almost to the big 10K!
    That number sounds like the model or serial number of the board. Your motherboard or computer manual will tell you what it supports. Worse comes to worse, ATA-66 ports tend to be BLUE on the motherboard
  10. Peter McDonald
    Jul 24, 2001
    204
    I didn't get a motherboard manual with the computer. And the computer manual is junk. It shows how to turn on/off the computer, install RAM, and install expansion cards... horrible documentation. I'll open up the computer later and see what colour it is.
    Peter
  11. Peter McDonald
    Jul 24, 2001
    204
    I've been reading on Intel's site, and I have found out that my motherboard doesn't support ATA/66 (chipset limitation).
    ATA/66 works on 810 chipsets using the I/O Controller Hub 82801AA (ICH), not the I/O Controller Hub 82801AB (ICH0). I have the 82801AB (ICH0)... damn.
    Does anyone know a good online tutorial that shows how to clean install Windows 98SE on a new hard drive? (detailed too)
    Peter
  12. Peter McDonald
    Jul 24, 2001
    204
    Update
    Well, I e-mailed the tech support of the people who made my computer (IDot). And they said it supports ATA/66... which is strange. I doubt it will work at ATA/66, but I may as well give it a try.
    Peter
