Ted Lee
- May 8, 2001
parents....might wanna leave that part out...
Check storagereview.com for good drive reviews. The Western Digital drives with 8MB buffer are currently the fastest available IDE drives.Questions:
* Does ATA133 make a difference over ATA100 in this comparison? I've got a Maxtor ATA 133 drive (and my MB supports 133) and I need to add a second drive. Are these WD drives, even though they have use ATA100 still faster than the ATA133 drives (If they are, I'd assume it's mostly due to the cache.)
* I can mix & Match an ATA 133 & 100 in the same machine right? If I put them on the same channel, will it run at the slower speed? If I put them on different channels, will that allow one to run at 133 & one at 100?
Questions:
* I can mix & Match an ATA 133 & 100 in the same machine right? If I put them on the same channel, will it run at the slower speed? If I put them on different channels, will that allow one to run at 133 & one at 100?1. No. No ATA drive can transfer enough data to fill an ATA/100 interface. Your highest end ATA drive (the WD Caviar SE) can only push about 30MB/sec of data through most of the platter, given absolutely optimal conditions. They peak at about 45-50MBps at the outer edge of the platter with 0 fragmentation, under ideal circumstances. It would take 3 of these drives in a RAID 0 configuration to come close to saturating an ATA/100 interface with sustained transfer.
2. You can mix and match, but it would run at ATA/100, correct. Again though, it won't really matter.
