New DVR - No place for connection
Discussion in 'Beginners, General Questions' started by Arthur, Feb 8, 2005.
  1. Arthur
    Arthur Extra
    Feb 19, 2004
    16
    My home theatre is all working fine until I purchase this Pioneer DVR 420.
    Nec Plasma, Motorola Cable Box, Zenith 318, Marantz 7300 ose. They are all connected via component cable thru the receiver (only 3 component connection)and all using digital sound.
    Now, where do I connect the DVR? Connection will be a S-vIDEO cable since all available component are all taken. Do I use VCR line or any other line in the receiver? I want to able to watch and record other channel and please provide in detail how to connect it.
    Thanks in advance.
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    not sure if you can do the watch one channel/record another with your setup.
    other then that, you can simply connect your dvr to any of the s-video outputs on your other gear. i'm sure at least the cablebox and dvd player have one.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Does the DVR have a basic cable/NTSC Boradcast tuner in it?
    If it does, in addition to the svideo, you would need to split the cable before the cable box to watch a different program than you are recording. Or a 2nd cable box.
  4. Arthur
    Arthur Extra
    Feb 19, 2004
    16
    It's NTSC broadcast tuner. We'll anyway, I connected a separate video from TV to the Receiver (S-video cable) then used the VCR connection from the receiver by the using the a/v of DVR and the receiver plus the toslink cable. Also, connected the RF cable from Motorola cable to DVR.
    The video is working when I switch the receiver to VCR and the plasma to VIDEO 3, but I can't get NO audio for recording nor just watching video while the DVR is on.
    I'am missing a connection somewhere? HELP!!
  5. Mike Wilk
    Mike Wilk Stunt Coordinator
    Jun 12, 2003
    84
    You can get Y-jack splitter for the audio. Shouldn't be more than say $10US. I split mine so I don't need the receiver for ordinary playback.
    YMMV
  6. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    If you want, you can buy a switch for the 4th component line. (This is just for the video). You can use common composite (yellow/red/white) 3-way splitters that are in just about every store that carries TV sets.
    You'd have to buy another component cable, though. As for the audio, some receivers have both types of digital audio sockets.
    Glenn
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    Where are the DVR's audio output jacks connected?
    Also, if you are using the TV speakers, the Video 3 audio jacks in back of the TV must be fed in order to get sound when you select Video 3.
    Video hints:
  8. Arthur
    Arthur Extra
    Feb 19, 2004
    16
    DVR Audio Out to IN of the Marantz receiver.
    DVR Audio IN to CABLE/SAT Out.
    Also, the digital (toslink) from DVR connected to Marantz receiver.
    The plasma tv does not have speaker.
    Keep in mind that when I play regular DVD on the DVR the audio works. Only when I want to record that I get no sound.
