new DirecTV DVR connection
Discussion in 'Playback Devices' started by Robb Cadigan, Apr 14, 2006.
  1. Robb Cadigan
    Robb Cadigan Auditioning
    Sep 16, 2002
    12
    I just upgraded my original DirecTV receiver to an HD DVR. Unfortunately the new outputs are a little different.
    I'm running to a Marantz projector. Originally, I was doing this through a RGB cable connection, but the new DVR has no RGB output. It does have the HDMI output, however.
    Is there an adapter to connect the HDMI/DVI cable to my RGB cable? If so, is this a good idea, or should I just set up a component connection with three cables. Or is there another route you suggest?
    I hesitate to buy a HDMI/DVI cable to connect directly to the projector as it would have to be a pretty long cable and I already have the existing RGB cable.
    I'm new at this and unsure what connection will give me the best picture, esp in HD.
    Thanks so much for any help and advice!
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,303
    59
    9,110
    Mississippi
    The people who have compared HMDI to component have said there is very little difference. If you want to use RGB, you will need a transcoder to convert the signal which will probably cost more than the long HDMI cable. Depending where you buy, you can get some 20 to 30 foot HDMI cables for around $50.
    -Robert
  3. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,624
    44
    1,610
    edit - sorry, misread the post
