John Pine
- Feb 27, 2002
- John Pine
This seems to be the case on several multichannel SACD's I have. Just bought the 2900 Saturday. Hooked it up to my H/K 525 and I am using the “6 Channel Direct” input. I have the following setup in the “Audio Setup”...“Speaker Config”:
Front sp: Large
Center sp: Small
Subwoofer: Yes
Surround: Small
Filter: On
DVD-A sound seems fine. Before installing the 2900 my system was calibrated using Avia and an RS meter at 85db. On installing the 2900, I used the “Manual” test tones and only had to adjust the rears slightly. Should I recalibrate and send the Avia pink noise through the "6 channel direct" connections? I'm sure I’m missing something. Any suggestions. Thanks!
Setup:
Toshiba 35" TV (s-video)
Harman/Kardon AVR 525
Denon DVD-2900
JBL S310-II's
JBL S-Center II
JBL S36-II's(rears)
Velodyne CHT-12(sub)
23'x18'x14'(LxWxH)room
Front sp: Large
Center sp: Small
Subwoofer: Yes
Surround: Small
Filter: On
Setup:
Denon DVD-2900
JBL S310-II's
JBL S-Center II
JBL S36-II's(rears)
