New CSultra sub to replce PC+ sub
Discussion in 'Archived Threads 2001-2004' started by Wendell, Oct 22, 2002.
  1. Wendell
    Wendell Stunt Coordinator
    Jul 23, 2002
    96
    will the Ultra sub work in the 20-39PC+? Will it sound any good?
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    It would work (essentially same enclosure as the ultra), but I think the driver cut out holes are different sizes and the mounting screw holes are in different places, so the replacement can't be made. Should double check with SVS on that one though.
  3. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    You cannot use the Ultra driver in a PC+ enclosure. The PC+ amp is specifically optimized to the dB12 driver of the PC+.
    TV
  4. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
    I second Dustin - I've heard this discussed before and the two drivers are not interchangeable in the CS+/PC+ enclosure.
    My advice is to have SVS custom build a "PC Ultra" - they do take custom orders.
    Ed
