Shawn Solar
- May 12, 2001
New 10" sub using XBL^2.
specs:
Fs-27hz
Re-3.3ohms
Qms-3.4
Qes-.48
Qts-.43
Vas-79L
Sd-345cm^2
Bl-9.09
Le-.9mH
Xmax-18mm
Pmax-300Watts
whatcha all think. Its pretty decent 10incher. Good for over 105db in a ported box at a low 20hz-25hz. sealed is fairly decent in a 1cube box. details found at
http://www.creativesound.ca/
specs:
Fs-27hz
Re-3.3ohms
Qms-3.4
Qes-.48
Qts-.43
Vas-79L
Sd-345cm^2
Bl-9.09
Le-.9mH
Xmax-18mm
Pmax-300Watts
