Mike_Boulanger
- Mar 5, 2000
Posted this on avsforum, figured I'd post it here too!
Been doing a lot of reading here, and thought maybe I should post and get some advice, plus maybe clear my head a bit to put it all down in words.
In the middle of purchasing a house, new construction, drywall not yet up. I've gotten permission from the builder to do my own low-voltage wiring.
I plan on using the family room as my home theater/entertainment room. My office will be located eventually in a finished basement. For now, it will be located in an upstairs bedroom.
Here's what I'm thinking:
RG-6 (for video distribution)
2 runs to each bedroom from basement
2 runs to living room from basement
2 runs to kitchen from basement
2 runs to dining room from basement
4 runs to family room closet from basement
2 runs to family room location 1 from basement
2 runs to family room location 2 from basement
Cat6 (for data hookups)
14 Gauge (?) Speaker Cable (for whole-house audio)
2 runs to master bedroom from basement
2 runs to family room from basement
2 runs to deck from basement
Cat5e (located near room entrances for future audio controls/IR sensors)
1 run to master bedroom from basement
1 run to living room from basement
1 run to kitchen from basement
1 run to dining room from basement
1 run to family room from basement
1 run to deck entrance from basement
Family / Home Theater Room
2 VGA runs from projector location to family room closet
1 DVI run from projector location to family room closet
8 14 gauge speaker runs to family room closet (7 speakers + sub)
1 RG-6 coax run from sub location to family room closet
I'm also considering security system wiring, but that I know less about. Any tips on what/where to wire for this would be helpful.
This is very overwhelming - it's easy to just go crazy on it, but I'm trying to do it as simply/quickly/efficiently as possible to not aggravate the builder who is being very good about the whole situation. I want to get in and out of there as quickly as possible.
Here are some questions:
- How important is the brand of RG-6 cable? I see lots of people recommend, say, Belden 1694a for RG-6 runs, but at about $270 for 1000' it's expensive. I don't have endless pockets and costs are adding up so would like to save wherever possible. For example, Parts Express has 1000' of solid copper core RG-6 for $64, and quad-shield for $128.
- Is quad-shield RG-6 important, and why?
- I plan on nailing boxes to the studs for my data/RG-6 and control runs, but not sure exactly what to do with the in-ceiling speaker cable runs. Again, the less bother I am to the builder the better, so I don't want to ask a lot of questions - however, I want to do it right for me and the guy doing the drywall. Are there in-ceiling speaker boxes to mount up? Or do I just leave the wire hanging? If so, how does the drywaller know where to cut the holes? Or do I just measure the locations well and cut the holes myself when I install the speakers?
- Anything else I should be thinking about?
Any help, answers, tips, comments would be GREATLY appreciated...
