New B&W 602s3 and LCR-60 thoughts
Discussion in 'Archived Threads 2001-2004' started by RobertSchaez, Jul 13, 2002.
  1. RobertSchaez
    RobertSchaez Stunt Coordinator
    May 1, 2002
    110
    Does anyone have any thoughts on these speakers? I generally liked the 603s2s for mains, except for a little too much mid-bass. Now that my budget has gone the way of the economy, I've had to set my price range a little lower. I will be combining them with a Yamaha RX-V3000, probably with the 601s for surrounds. (65% music, 25% HT)
  2. John Dunlap
    John Dunlap Stunt Coordinator
    May 8, 2002
    157
    You'll find that quite a few people here prefer the 602's to the 603's. If you have a sub I really doubt that you'll be missing much by going w/ the bookshelves. I love the 600 Series. Great speakers for the $$.
    One thing though, if your budget allows I would go for the LCR600 rather than the 60. I never compromise on the Center Channel.
  3. Hyun K
    Hyun K Stunt Coordinator
    Apr 18, 2002
    80
    I prefer the 602's over the 603's. 602 + sub will provide just as good if not better performance than the 603 alone. Give it a listen as see what you think. Don't skimp on the center channel.... it's the most important for HT. Don't get the LCR600 however. If not the LCR60.... pay $100 more than the LCR600 and get the CDM CNT.
  4. John Dunlap
    May 8, 2002
    157
    Hyun,
    The only reason that I did not recommend the CDM-C was that I did'nt think it was timbre matched to the 600 Series. I'm not a B&W owner so I don't know for sure.
  5. Will Pomeroy
    Will Pomeroy Stunt Coordinator
    Feb 9, 2002
    144
  6. RobertSchaez
    May 1, 2002
    110
    OOPs, I knew I should have used a calculator!. No, I meant 65% music, 35% HT. BTW, wht do you mean by the Midrange is colored?
  7. Hyun K
    Apr 18, 2002
    80
    John... I own both the CNT and 602S3. Of course the timbre is not EXACT as the LCR 60/600, but it still blends in great and you can have a seamless soundstage with it. Especially for HT, the pros of the CNT over the LCR60/600 (higher clarity & detail, off axis performance) far outweigh the slight differences in timbre which won't be even noticed if the speakers are set up properly.
  8. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    I just saw at Tower the new issue of What Hifi? a British stereo magazine.
    The new 602 Series 3 won a bookshelf shootout with 5-6 others in same size/price range.
    Might be good reading on the subject...
  9. RobertSchaez
    May 1, 2002
    110
    Thanks Lee, I'll have to check that out.
  10. Arron H
    Arron H Second Unit
    Jan 17, 2002
    332
    Interesting that the 602s are still categorized as a bookshelf. It seems like there should be a middle category between tower and bookshelf for speakers like the 602s, Studio 40s, etc. The 601s are more like what I would consider to be a bookshelf speaker.
  11. RobertSchaez
    May 1, 2002
    110
    Thanks Hyun, I'm not sure if I can stretch the budget , or if I like the looks and size, but I'll put the CDM-CNT into the mix.
    Rob
  12. Myki Cantero
    Myki Cantero Stunt Coordinator
    Jun 5, 2002
    119
    I have a small living room (14ft x 10ft) and I live in a condo so I decided to get the 601 S3 rather than the 602 S3 for my front speakers. I listened to both 601 and 602 for a looong time and I find them very similar except with the lower bass of the 602. I let my B&W subwoofer take care of the low frequencies.
    The 602 looked too big for me. It's like floating "floor-stands" to me. :) But if I had a bigger living room (and a 50" TV), I would definitely get the 602.
  13. Josh P
    Josh P Agent
    Jul 21, 2002
    27
    I agree with the posts above, the 602's with a sub do better than than the 603's. (midrange/vocals too forward) Definatly go with the LCR 600 centre as the 60 lacks strength. I found the LCR 600 to meshed better with my 602s however they were still a little weak. (could be my crappy reciever) I did find biwiring (with cheap cable) my LCR 600 improved the clarity of voices in movies. Enjoy
  14. NickC
    NickC Second Unit
    Jan 19, 2000
    290
    does anyone happen to know the msrp for the lcr 60 and 600? I have B&W 602 s3 and In the next week or so I am going to be buying a center channel speaker, which would be the better choice?
  15. Bry_DD
    Bry_DD Second Unit
    Dec 29, 2000
    340
    I think the 60 is $350 and the 600 is $500.
  16. Bob-N
    Bob-N Supporting Actor
    Jul 26, 2001
    915
    Go with the bigger LCR600. They're a better match with the 602's. The 60's have smaller mids and don't have the punch and clarity that the 600 has.
  17. NickC
    NickC Second Unit
    Jan 19, 2000
    290
    I am stuck with two options, what does everyone think is best, right now I have one pair of b&w 602 s3's, I want to get a full 6.1 setup, I could do one of the following
    A:
    L/R - 602 s3
    Center - LCR 600
    Rear 602 s3
    Rear Center - LCR 60
    B:
    Get three Pairs of 602 s3's for front and rear speakers( I know a few people here have done this and love it, am I losing anything for home theater with this option, the system will probably be like 40% movies, 30%games, 30% music)
    any thoughts?
  18. Bob-N
    Jul 26, 2001
    915
    If you have the room and don't have placement issues (both centers), I'd get 3 pairs of the 602's. Seamless timbre match all around. The ideal situation for both HT and multi channel music.
  19. NickC
    NickC Second Unit
    Jan 19, 2000
    290
    Is there anyway to get the 602 s3 magnetically sheilded? I just remembered that the 602 isnt sheiled, I put one next to my tv and saw some minor distortion on the corner, when I put it on the top of the tv a saw a lot more distortion..
  20. NickC
    NickC Second Unit
    Jan 19, 2000
    290
    Since the 602 s3 isn't sheilded looks like I am going to have to go with the LCR 600, I think that it is a better choice over the 60 and matches the 602's better. thanks
