Eric_Singer
- Apr 11, 2002
Hi,
I recently replaced my H/K AVR70 with separates - an H/K PA5800 with a PT2500 preamp. It works fine, but there is an audible background buzz that comes through the speakers now. It comes through each speaker equally loud, and changing the volume level of the preamp does not change the volume of the buzz. This, combined with the fact that there was no buzz before, leads me to believe that there is a problem with the amp's electrical connection. The amp uses a 2-prong plug with no ground, so I presume it would be safe to flip it around, but it only fits in the outlet one way. Would it be ok to use a cheater plug to flip it around, and would this likely solve the problem? Is there anything I am missing here? Any other possible sources of the buzz, or any other possible ways to fix it?
Thanks for your help,
Eric
Eric
