new 57hdx82 picture size questions?
Discussion in 'Archived Threads 2001-2004' started by jeff_coil, Dec 6, 2002.
  1. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    Hello, well I have had the new set for about a day and it looks great. However after reading the manual it states that the recommended viewing for wide-screen format is natural mode. However when I select this mode when watching a DVD (spiderman) from my Dennon 1600- which is also new there are gray letter boxes on the right and left sides and it appears to be stretching the wide screen pic in to a 4x3. theater 1-3 and full fills the screen with different levels of streching. Is this normal?
    Other than this the set awesome and has no speaker his as I have read on here in the past
  2. jeff_coil
    Dec 3, 2002
    157
    Well from what I can tell this is normal and the Toshiba manual is confusing. Full mode is the mode to use! BTW Ice age is on right now and it looks fan-frigin-tastic!
  3. daneli
    daneli Extra
    Nov 16, 2002
    17
    In Short the modes to use are as follows:
    Full mode: Anamorphic DVD
    Theater Wide 1: 4x3
    Theater Wide 2: Cropped Anamorphic DVD (get rid of upper and lower black on higher aspect ratios)
    Theater Wide 3: Don't use it much
    Natural: Gray Bar 4:3 or Full Screen HIGH Def
    DanEli
  4. jeff_coil
    Dec 3, 2002
    157
    Thanks DanEli! How long have you had your set?
