New 2nd TV Cable Woes
Discussion in 'Archived Threads 2001-2004' started by Mark Zimmer, Nov 5, 2001.
  1. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,300
    40
    I just got a 2nd TV (Toshiba), and when I hooked it up to cable, some of the channels don't come in very well; they have diagonal banding on them that's kind of irritating. However, other channels look great. They all look fine on my first TV.
    Any ideas? I did calibrate the #2 TV with VE. I tried calling the cable co. but they just held out the prospect of an ineffective service call at $X/hour.
    "This movie has warped my fragile little mind."
  2. Richard Burzynski
    Richard Burzynski Second Unit
    Jun 30, 1997
    466
    Mark:
    "They all look fine on my first TV"
    This is key. If all channels are fine on the first set, it's probably the split. The signal to the second set isn't as clean.
    Some possible reasons:
    * real cruddy cheap splitter.
    * interference (is the 2nd room coax cable touching other cables/wires along the way?)
    * cheap cruddy quality coax cable for 2nd room run - try to use RG6 not RG59.
    * could be just weak signal to begin with that loses more w/ the split. A coax amp can be a final solution if the above items aren't the problem.
    I've used an amp for 3+ yrs now and people usually comment on how "clean" my cable signal looks. But look at the other items first.
    Hope this helps.
    Rich B.
  3. Mark Zimmer
    Jun 30, 1997
    4,300
    40
    Thanks, Rich. Gives me some things to try.
