Troy TN
- Apr 2, 2000
I sold my M&K mx200 with dual 12" drivers and internal 200 watt amp for 20-39pc. I REALLY want to love svs but it does not thump like the M&K did. I could never have the amp volume above half on the M&K and my chest was pounding and my hair moving. With the 20-39pc nothing. I turn it to 3/4 ouput and it just cuts off or mutes and comes back on. It cycles like this over and over again. I calibrated to 80db and tried The opening to Toy Story 2 and the sub shuts down each time. I brought the sub amp down to under half and then will it only stay on during this scene but I cannot hear it at all with any other material at this level. I notice a small rattle under the amplifiers heat sinks as well. It sounds like a loose screw. I cannot get it to stop rattling. I have the Denon 5800 with a 2000 square foot room.
With all the great reviews I must be doing something wrong or does the svs sound that much different from other subs that I may not be used to the svs sound? All of my DTS cd's had heart pounding bass, nothing from the svs. The Antz scene with the stomping foot. Nothing like before. It has to be defective or I'm doing something incorrectly. I assume a sub either works or not. I am gettng sound from it just not the levels I had been used to.
I have sent in two emails to svs support this morning about 7am (Friday) and not heard anything yet so Maybe they can tell me what I'm doing wrong. Many of you that have svs pc subs state you cannot even stay in the same room its so powerful. I want that! I know my M&K was more boomy which is not good but I felt it as well.
I'm thinking maybe I should go with dual 25-31cs' and a samson amp, One cs ultra & amp, or back to M&K. What are your thoughts?
One 20-39pc is not working. I understand my previous M&K sub is twice the price of the 20-39pc. So it may not be fair to compare. But my other two options above may be closer to what I'm looking for.
Any suggestions from ye fellow svs lovers and owners would be appreciated?
Thanks in advance for your responses.
