Chas_T
- Jun 1, 2002
I am trying to network 2 PC's, one using WinXP and the other with Win 98 Version 4.10.1998. For the record, I also used the file netsetup.exe on the 98 machine, which XP suggests when the 2 operating systems are used in a networking XP platform.
The problem is that ZA, Ver. 3.7.202, blocks each others IP address's EVEN after adding them to ZA's trusted zone on both machines in the IP firewall area.
The IP addresses are 192.xxx.x.100 (XP machine) and 192.xxx.x.101 (98 Machine). The router I am using is the D-Link DI-604 and the NIC cards on both machines are the D-Link DFE-530TX.
When I drop the firewall on both PC's, the network has NO problem sharing and seeing each others drives and printer. When I engage the ZA firewall, even AFTER adding the IP address to the trusted zone on each individual PC, ZA still blocks access. I've gone over the IP numbers numerous times making sure I am correct and everything is in order.
I am rookie with this stuff, but I'm confused as I've done the same thing on my PC at home and after adding IP address's to the trusted zone between 2 XP machines, ZA allowed access.
I'm attempting to do the same thing with my girlfriends computer and ZA will not allow them to talk to one another. What am I missing here? Your help is appreciated as I am at my wits end with this.
Charles
Charles
