Networking W2K and XP file sharing
Discussion in 'Computers' started by Keith Outhouse, Jul 10, 2003.
  1. Keith Outhouse
    Keith Outhouse Stunt Coordinator
    Feb 2, 1999
    91
    My 2000 machine can see my XP shares but not the other way around. Both can ping each other. Do I really have to reconfig my 2000 networking using the XP CD??
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    What permissions do you have set on the shares on the XP box?
  3. Keith Outhouse
    Feb 2, 1999
    91
    I set up a share called c at the root of C:. I'm pretty sure I set everyone to full. If permissions trouble wouldn't I just get access denied when I tried to open the share?
  4. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    I would have thought so, Keith.
    I presume both machines are in the same Workgroup?
    When you open your network places, can you see the 2000 machine at all?
  5. Keith Outhouse
    Feb 2, 1999
    91
    They may not be in the same workgroup. I'll have to check that tonight. No, I can't see the 2000 machine at all from XP. I even tried a net use command and it failed with an error. Don't remember the error, it was late.
  6. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    Keith, that sounds like a Workgroup problem.
  7. JamesHl
    JamesHl Supporting Actor
    May 8, 2003
    813
    Try opening a window and putting \computernamehere in the location bar, see what it says.
  8. Diallo B
    Diallo B Screenwriter
    Dec 18, 2002
    1,076
    I am not exactly sure but I do remember when I configured my network and file sharing that a computer with win2000 can see an XP computer but an XP computer can not see a win2000 computer. I know that I am oversimplifying things. I will look it up and post back. By the way I have two XP machines networked and I think that is the best way to go.
    djb
  9. Keith Outhouse
    Feb 2, 1999
    91
    Thanks everyone. I'll look at the workgroup settings tonight.
    Diallo, that sounds like what I'm seeing. Let me know if you find more info. This is a temporary setup while I transfer, reload, configure, etc. Later the 2k machine goes away.
  10. Diallo B
    Dec 18, 2002
    1,076
    This link may help to solve your problem if you are running XP Pro. Also, I am pretty sure that you have to use the XP cd to configure your network on the 2000 machine. The info that you are looking for is about 60 percent down the page.
    http://www.practicallynetworked.com/...ring/whole.htm
    good luck.
    djb
  11. Keith Outhouse
    Feb 2, 1999
    91
    Great link! I'll play with it tonight.
    Keith
  12. Keith Outhouse
    Feb 2, 1999
    91
    Well, Rob had it right. Once both machines were in the same workgroup, I could browse to the share. I had to supply an account and password to access the share. Thanks to everyone who helped.
