Hi all,
I recently purchased an ONKYO TX-NR6100 and I am having an intermittent issue when trying to use the NET function and was wondering if anyone else has had the same issue and been able to resolve it. When the issue occurs, after about five times of using the NET function to stream Spotify, the display on the NVR shows 'Now initializing. Please wait...' and just hangs there. The TV screen just shows a blank blue screen. I can change inputs on the unit and they work as normal but as soon as I go back to the NET input it shows the same message. The only way to get it to work again is to power cycle the unit. Simply turning it off and on with the remote or front button doesn't resolve it. I have looked on other forums and this seems to be a consistent issue with various ONKYO models and I can't find a published fix for it. The unit is connected by ethernet (so WiFi vagaries are not the issue) and no other devices on the network have difficulty maintaining a rock solid connection. I have been through all the typical steps with the ONKYO Technical Support Team (firmware update, factory reset, etc) and they haven't been able to resolve it.
Any advice?
Any advice?
