Skiliq
- Nov 23, 2009
- Chad
Hi,
Just bought my first condo, and ran into the problem that if I am playing a video, or watching a movie or tv, that the neighbor says he is feeling vibrations in his bedroom. The condo is 3 stories, the very bottom is a two car garage cut into the hill, so most of the side wall and all of the rear wall are cement blocks. The story above the garage has the living room, dining room, and kitchen. Laminate floor in the living room and tile in the kitchen. the story above that is the bathroom and loft style bedroom, which the upper half of the wall that faces out over the living room is open. It has tile in the bathroom and wood in the bedroom. The living space is 865 sq ft, and the only spot where the units are joined is at the kitchen and bathroom wall.
I have the Onkyo HT-S9300 THX system, and currently the sub is in the front of the room, the opposite corner of the condo from where the shared wall is, and is facing in the direction of the shared wall. On the receiver I currently have the sub set to +0.0 db, same for the bass. When you are in the living room, kitchen, or dining room you do not feel any type of vibration. But if you go upstairs to the bathroom, then you are feeling the bass from the system, and it is vibrating thru the bathroom wall, into the neighbors bathroom and out into their bedroom.
Add to that, that they go to bed pretty early and I am more of a night-owl, this is kind of a problem, and they are nice neighbors so I want to be considerate to them.
I doubt that there is any insulation in the shared wall, but I was not sure if I saved up and spent money on having insulation pumped into that wall if it would fix the problem.
Or would it help to move the sub behind the couch on the other side of the room so that it is facing away from the shared wall?
Any thoughts? Suggestions?
