Phil Florian
- Mar 10, 2001
Howdy!
If any site can recommend one, this would be it! A while back I purchased an APEX PD-10 portable DVD player. Got it nice and cheap and it has been a great way to play movies for long car rides. Yes, sure, they come better and cheaper now but I don't want to re-buy yadda yadda yadda.
Anyway, it came with a dinky remote that stopped working a while back. No battery changes helped. Gone. Dead. Kaput. I bought a universal remote that looked good but while it listed Apex as a brand it supported, the PD-10 wasn't one of them. If the buttons on the machine did more than play and fwd and rev I would be okay but it won't let me move through menu screens or any other useful function that is DVD. I tried all the various codes in the book for APEX and others but it never worked. I got some random functions (like PLAY would cause it to FWD or MENU would cause it to PAUSE but never did button match function at all and never enough functions to say "heck with it, I will memorize the new button lay out).
I have tried without luck finding decent replacements of the remote. First of all, it wasn't cheap. Secondly, it was a cheap piece of crap to begin with so chances are IT would break soon. So my thought is get a good remote that truly is Universal, if there is such a thing.
Any ideas? Work arounds? Hints? Allegations???
Thanks!
Phil
Thanks!
Phil
