Need your help: I'm finishing my H/T Room's ceiling!
Discussion in 'Archived Threads 2001-2004' started by Dan Smith, Jan 8, 2001.
  1. Dan Smith
    Dan Smith Agent
    May 2, 2000
    27
    I'm finally ready to finish my H/T Room's ceiling. I need recommendations on what type of tiles to purchase. Should I do a suspended ceiling with some sort of acoustic tiles? I don't have a huge budget for this, also I plan on selling the house in ~two years. Home Hardware type recommendations would be preferable.
    Thanks in advance guys for your help and guidance [​IMG]
    Wizard's First Rule:
    People Are Stupid: They believe what they want to believe because they want it to be true, or because they are afraid it might be true! Zeddicus Zu'l Zorander
    [​IMG]
  2. Andres Munoz
    Andres Munoz Cinematographer
    Dec 21, 1999
    2,489
    Though I'm no expert in this by no means, I would recommend a drop ceiling with acoustical tiles.
    I just bought my house 3 months ago and the basement came with a drop ceiling. It helps very much for running cables and hiding them from view.
    I run all my speaker cabling up there and an S-video cable from the back of the room where the components are, to the front of the room where the TV sits.
    If I didn't have a drop ceiling, the cables would have gone under the carpet, which is a real pain in the ass to do.
    Andres
  3. Dan Smith
    Dan Smith Agent
    May 2, 2000
    27
    Does anyone know what type of acoustical tiles a should buy from a Home Hardware type store. I know that there are many types available. Do I want to absorb sound? Reflect it? Absorb only high frequencies? Lows? Can you absorb too much?
    As you can see I have no idea. Does anyone have recommendations on the tiles?
    Thanks [​IMG]
    [​IMG]
  4. Steve U
    Steve U Extra
    Feb 20, 2001
    20
    Any thoughts on this, along with possibly painting the tiles a very dark color to "disappear" when the lights go down? Has anyone ever done little pinholes or LEDs to simulate stars in the ceiling? Just some ideas I was thinking about while staring at my blank basement wall...
  5. Robert M
    Robert M Agent
    Feb 11, 2001
    27
    When I finished my dedicated theater my main concern was sound containment, not room acoustics. With a great deal of research I located a sound absorption material called Sonopan ( available at lumber companies) it is 3/4" thick, and I applied it to all joists and beams. 8" of insulation wool was first applied, the the Sonopan, resilient [email protected] 12" on center then two layers of 1/2" drywall. I then applied a textured paint to the ceiling, and painted very dark blue. I am very happy with the results as only the lowest frequencies seem to escape the room. To carry the cables in the walls and ceiling I used a conduit using central vac piping. There is very little echo in the room, which has a deep pile carpet on the floor and thick velvet curtains around the screen and 48" up the wall past the front speakers.
    I had a consultant on the job with me, and he indicated that the ceiling should be slightly reflective as THX speakers are very good at eliminating vertical dispersion.
    Hope my experience is a help.
  6. MichelF
    MichelF Extra
    Feb 17, 2001
    23
    I would suggest Armstrong ceiling. Have a look at: http://www.armstrong.com/
    I recently installed an Armstrong Parafon Fjord ceiling in my HT room. Very nice looking and excellent acoustic characteristics (Armstrong has a lot of different type of ceiling and their brochure give all the details about all the possible characteristics: acoustics, resistance to fire, to moisture, etc). The Parafon Fjord is one of the best in terms of acoustic.
    MichelF
  7. Dan Smith
    Dan Smith Agent
    May 2, 2000
    27
    Thanks guys, I think I'll go for the simple route since I'm gonna sell the house in a few years. I'm gonna check out the Armstrong products.
    P.S.: Sounds like you go a great H/T Robert. [​IMG]
    [​IMG]
